Results 1 to 10 of 11
Thread: Removing rear block...
    Dec 2008
    Amarillo, TX
    Exclamation Removing rear block...
    I think I have decided to remove the rear block on my leaf springs. Will this be ok? No harm to the truck, right? I still tow a little. Nothing heavy (over 2000 lbs).
    '08 Silverado Ext Cab 4x4, 5.3L, 3.73... K&N FIPK, Bully Dog, GM Performance cat-back exhaust, Removed rear block (leveled), KMC Badlands 18x9 with Cooper Zeon 285/60
    Aug 2006
    Houston, TX
    Won't be a problem at all, may want to look into getting some shorter u-bolts tho?
    05' SIERRA RCSB
    Southern WI
    +1 on the shorter U-bolts, I don't know about the NNBS trucks but on the NBS you can use the 2wd bolts. It won't hurt anything by taking them out either.
    Mike
    2000 RCSB
    No harm to your truck but your friends may want to harm you for some reason folks get really defensive when you make a 4x4 lower.
    Its okay we support you though. I did it on my 02 Z71 and when I hooked up my friends boat it was awesome because everything from truck to trailer was perfectly level. I loved it
    Plus if the nnbs 4x4's are anything like the 2wd they really need to lose some height on the back
    MKader17
    i removed mine in my 99 z71 and it didnt do any harm and i even have 2 inch drop shackles as well...i jus need to cut the bumpstops smaller
    Go for it no harm at all I took mine out and also put in a drop shackle. Your right when I start to tell people I dropped my 4x4 they get all worked up.
    Also you should use new u bolts every time there only like $20.00 a set. beside its faster to just cut them out and use a new set. good luck!!!
    Jeremy
    2000 Sierra 4x4 Denali front, 5.3, 3/4 drop, 22 foose speedsters, roll pan, Cold Air, Cat-back.
    Quote Originally Posted by Jeremy K View Post
    From where? mine were almost $50 shipped from GM.
    MKader17
    Dec 2008
    Amarillo, TX
    I got mine from Rough Country.
    Maui, HI
    I remember when I did this but probably did it a "dangerous" way without knowing... I put the block on top of the leafsprings and just re-used my u bolts. Had to ground something to get the block to sit flat on the springs.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    Houston, TX
    I have a set of 2" drop shackles for sale in the sales section if anyone is interested.
    2014 GMC Sierra Crew Cab
    -5.3
    -Gibson Exhaust
