Results 1 to 10 of 11
Thread: 34" radiator swap
    Feb 2009
    brooks, alberta
    34" radiator swap
    for those who have done it, does a 34" bolt in place of a 28 inch unit, anything need to be modded for it to fit? i have e-fans already. oh, its a used rad off a 03 2500, rockauto says same rad as an 05 half ton, there the same right?
    2001 gmc 1500HD SOLD...new truck 2004 sierra
    San Marcos Texas
    It bolted right in mine!
    Feb 2009
    brooks, alberta
    thanks, think im going to do this swap
    Feb 2009
    Millen, GA
    it drops right in, only thing you need to do is trim the little rubber flaps on both sides. not a great explanation but you'll know exactly what i'm talking about once you get the radiator out.
    hot & windy
    i know the thread's old, but i'm thinking about going on & getting a 34" radiator while i'm doing the 4.3 -> 5.3 swap. are the hoses different between the V8 28" & the 34"?
    also, removing the rubber flaps on either side of the radiator won't hurt anything, will it?
    99 Sierra - 5.3 / 5spd
    Plainfield, IL
    blew my radiator today...putting a 34" in it's place...will let ya know later. will try to take pics
    Plainfield, IL
    brand new radiator from 06 silverado 1500, went RIGHT in. it's like .4 inch thicker, and 6 inches longer.
    hot & windy
    hoses fit?
    Plainfield, IL
    yes...but buy new hose clamps. With my body lift, that bottom one was a PAIN to get one/off. i have electric fans, since body lift, i feel i need a short lower radiator hose, but everything fit same as before. you just use the outter holes on rad support. VERY simple. took maybe 20 minutes, including wrestling that bottom hose.
    hot & windy
    awesome! thanks
