Thread: help!
    Chandler, Ok
    help!
    Okay thought my alternator was going out. battery was weak but start after a few turn overs. would run fine the rest of the day then it would happen a few days later so i replaced the battery ran like a champ! No a day later it turnedover once and just one click everytime you turn the ignition. Is it the starter?
    My names: MATT
    Drive: 1998 legend conversion silverado
    Status:Married, one gorgeous daughter, mystery baby on the way, and broke! Hopin to find engine soon...
    shirt size: Medium
    Aug 2005
    St. Anthony, Indiana
    get your alternator tested to see if it is putting out the right voltage.
    Racoon Twp., PA
    Check grounds, weak/bad grounds will give you lack of charge and drain battery quickly during cranking
    2013 CC 5.3
    81 C10 LS1 project
    Chandler, Ok
    Well battery isnt drainging anymore its notcranking just one click everytime you turn the key.?
    My names: MATT
    shirt size: Medium
    Ignition switch or starter. Beat on the starter with a hammer while someone turns the key or test for voltage at the purple wire on the starter while cranking. Have the starter draw checked too.
    Dec 2008
    Michigan
    sounds like the starter to me. sounds like 3 clicks REAL fast
    2002 Gmc Sierra Z71, Aeroturbine performance exhaust, 33" prospector all-terrains, built 4L60e, K&N CAI, newly installed Vette servo and .500 boost valve, soon to come S&B tune and headers
