Results 1 to 7 of 7
Thread: TH400 parts list
    ff_jeff Guest
    TH400 parts list
    OK, I have decided to go with a TH400.
    Question is, I need to know exactly what I am going to need to swap it in my 97 reg cab step side. It will be behind a lq4.
    I know some of you run this setup, so thats why Im asking.
    I know it will need a different driveshaft. What tail housing will it need?
    How will I shift it? Special stall, or spacer kit? Special U joint?
    Thanx guys.
    Pittsburgh, PA
    your body truck has already came with a TH400. search for those trucks then all youll need is a motor
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Slimsilverado Guest
    Get you a rachet shifter ya doushe, get you a stall of choice there are several kinds out there, remember a th400 in a non lock up style verter. U-joints should be easy to get ahold of. you will need a new Yolk for the trans, get a manuel valve body put in IMO.
    Driveshaft from 454 ss truck and correct flywheel. Got no idea what flywheel though.
    Nov 2006
    Mesquite, TX
    crossmember...a lot of stuff from a 91 3/4 ton will work also the VSS deal, hmm a shifter would be nice...i kept my column shifter just for grins....keep the tailshaft they build it with and you really shouldnt have a hard time cause like stated above your body style came with this trans in the earlier years
    jeff you should just go to a junkyard and find one with a TH400 in it and just yank all there ****
    southside VA
    this would be the best idea i think
