Results 1 to 10 of 30
Thread: LPP header installation....
    Feb 2005
    First of all this is on a C1500 2wd Silverado 5.3L Flex fuel crew cab truck. Secondly....I'll have pictures to post tomorrow but wanted to start in tonight.
    So far tonight, my agenda was to get as far as I could (starting at 10pm....its now 1:20...hahaha....wooohooo....). I put the truck on to some 8" car ramps and started to get organized. Unbolting the factory y-pipe is always fun and time consuming because it doesn't want to unbolt easily. But I didn't want to cut it because I had a buyer for it. So...I was patient. Anyways, removed the y-pipe and passenger side exhaust manifold. While it was out of the way, I installed a Sonnax 1-2 Servo (figured it would be the best time to do that). Installing the header was very easy on this side....went in from the bottom without a problem. Bolted it all to the heads using there gaskets (with the stockers on standby) and bolted right in. Checked for clearances between the primaries and the frame and I have at at least 3/16" away from the frame...probably more like 1/4". However, the headers tuck up next to the cab of the truck very nicely. I would say about 3.5" up from the bottom of the chassis. I was going to put on the y-pipe that comes with it until I came to a stopping point. The y-pipe will not slide onto the header because of clearance room. To correct this, you have three options: 1) Put the y-pipe on the header before you bolt the headers to the heads, 2) Bolt on the headers and unbolt the crossmember to the transmission and slide the y-pipe between the transmission and the brackets, or 3) Cut the end of the y-pipe about a 1/4" to clear it and install the y-pipe. I'll end up doing 2 or 3 tomorrow since I've already bolted the header to the engine.
    Now, the headers come with u-bolt clamps....I would not use these. I would run to your local Napa store and pick up a set of SS 304 band clamps (about 3" in width) and clamp them down. I have used these in the past with great success and no to mention...they don't hurt the pipes for later disassemble.
    Tomorrow I'll add some pics of the driver side header looking into the collector and passenger header installed.
    Oct 2007
    weatherford,TX
    just drop the crossmember it take like 3min
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
    Feb 2005
    I did before you replied. Got everything on the truck and runs like a top. You will definately have to get a tune because the DTCs will drive you crazy...luckly I have HP Tuners. However, I have band clamps on there right now and its quiet except for the place where I ran out of band clamps and add to put one of the u-bolt clamps there....and man does that thing not seal worth a durn. So, I'll be heading to the exhaust shop in the morning to get it welded up because NAPA doesn't have anymore in stock and will be a few days to get more. Other than that....no compliants at the moment. Just for a tip...do get band clamps or exhaust leaks will get the better of you.
    Dropping the crossmember is needed because you need to assemble the y-pipe before installing it. I tried to install it in sections and just wouldn't work. So, assemble the y-pipe and install it as one piece is the way to go. I'll add pics later on.
    Jun 2007
    Ocala, Fl
    yes please add pics.
    96 c1500, stock suspension, stock bottom end, 93 octane, street radial- 1.60 11.5 at 115- on the small stage-sold
    05 SSS 2wd 228/230/80e/fti4k/5,5drop/215shot-sold
    90 350ss... beast build
    cool write up
    Feb 2005
    San Antonio Tx
    me wants pics already
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
    Feb 2005
    Pics added.
    College Station, TX
    awesome write up, appreciate the time doing it!
    Feb 2009
    Roy, Utah
    Mine are supposed to be here tomorrow, did the stock o2 sensors reach the bung or did you need extensions?
    99 Silverado 1500 4X4- 6.0 LQ4, LPP headers
    00 Trans Am- H/C LS6 intake, 100 shot
    11.64@121 w/1.74 60' @4400' elevation
    Feb 2009
    Cape May, NJ
    mine should also be in on friday...thanks for the write up...good heads up!!
    trevor
