Results 1 to 10 of 13
Thread: Fully built Tranformance 4l60e with I6 TB stall.
    Apr 2005
    The Woodlands, TX
    I'm going to be doing my 4l80e swap next weekend so I'm putting this tranny and converter that's in my truck up for sale. Has approx 10k miles on the tranny and 40-50k on the verter. Been holding 500+rwhp with out problem and is in great shape and shifts very nice. Is currently setup for 4x4, but I can include a 2wd output shaft and tail shaft you could have swapped into it. Great for a Built NA or a mild FI setup.
    Converter is a DACCO remained I6 Trailblazer converter that has worked flawlessly. Dynoed over 500 rwhp with no slip locked up.
    Tranny has all the best parts put in it to compare to level 3 PB or 5 FLT.
    5 pinion GM planet sets
    Raptor Torque drive hardened and sleeved input assm.
    Superduty Beast sunshell.
    Complete roller bearing conversion
    Raybesos Blue Plate clutches, ect
    Trans Go HD-2 shift kit
    Corvette servo
    New reverse drum
    Wide 1-2 band
    4l70e TBSS cryoed 4x4 output shaft
    And some other stuff I'm sure I'm missed.
    Supposed to be pretty much the best he could build a 4l60e to. Is rated to hold 600hp/600tq in a heavy truck, probable more in a car.
    $1500 shipped with the converter. Will be complete with the bell housing.
    Pic of what it looked like before I installed it.
    01 ECSB 1/2 ton 4x4 6L GMC
    11.03@127
    KB Racing Borg Warner S475 turbocharged
    http://i3.photobucket.com/albums/y57/Kbracing96/kbracing96copy-1.jpg
    Feb 2008
    Arizona
    will it fit my truck? it's a 06 4x4.. I'm wondering cause I thought I read something about my truck having a 4L65e.. I'm not sure about that..
    how much for just the tranny?
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Aug 2005
    St. Anthony, Indiana
    it will fit in your truck.
    Apr 2005
    The Woodlands, TX
    Yep, the 4l65e is a 60 with the 5 pinon planetaries which this tranny does have, so technically it is a 4l65, lol. With out the converter I'll take $150 off.
    11.03@127
    Dec 2008
    san antonio TX
    how much do you want for the tranny the way it is in the pics without bellhousing, converter, tail shaft. i need it for my 99 z71 its slipping and shifts really hard out of 1st gear.
    Apr 2005
    The Woodlands, TX
    $1350 is as low as I'll go, I paid $2400 for this tranny 8 months ago
    11.03@127
    Apr 2005
    The Woodlands, TX
    Bump
    11.03@127
    Dang, when my transmission goes this is exactly what I'm looking for. Good luck with the sell!
    MKader17
    Quote Originally Posted by MKader17 View Post
    This is the transmission that blew at the meet... glad no one bought it
    Oct 2007
    Bandera, TX
    risk of buying used....lol.... u want the sale removed Kyle?
    single digit street truck
    for build info
