Results 1 to 10 of 11
Thread: th350
    th350
    does anyone run a 6.0 an th350 instead of th400???
    2003 silverado x-cab stepside fully loaded..nelson tune..green CAI..160 thermostat..ls6 intake..pacesetter LT's..3"magnflow hi-flow's..one chamber flow dumped..4L60E PATC 1-2 servo 4th servo..trans go HD-2..ridn 24's...2" 4" drop..detroit tru trac an 4.10's setin n the shop waiting
    Oct 2007
    Bandera, TX
    imo it would be like running an old 4l60e. th350 is prolly rated for about the same. 400 is much stronger and not alot more. just my .02
    single digit street truck
    for build info
    i understand that complety..i was asking cause i can buy one for 400 bucks rite now with straight cut gears and the whole 9 yards pretty much bullet proof out of my buddys 5.60's amx
    Oct 2007
    Bandera, TX
    but realize that what kills the trannys in a truck so bad is the weight. but it will bolt up the same as a th400. only one way to find out if it will hold
    for build info
    Nov 2006
    Mesquite, TX
    yeah i have seen some strong th350's being built but the th400's are that much stronger...but you can try and give it a shot...you arent making enough power right now to even worry about it IMO
    o yes i agree on that one if it was for my truck id never do it id go with a 400..it's goin n my firebird..my truck is jus a fun daily..im buildin a 94 f-body with a lq4 gt2-3 cam and 80mm bolted on the front
    Nov 2006
    Mesquite, TX
    well hell you didnt state that to begin with....th350 is the way to go in a f-body!
    Oct 2007
    Bandera, TX
    ya, the car info would have helped....lol.
    for build info
    sry about that wasn't thinking at first lol...it should be a decent car im hoping atleast..im swapin it from bein a v6 car so it's full tube k member an control arms (60lb lighter)...im tryin to keep up wit a vette 2 of my buddy r building at BPM but i don't c it hapinin lol
    Jun 2007
    Ocala, Fl
    i was gonna say i run a th350 and have had no problems. my truck has seen countless passes on the street. and we copyed the tranny build my uncle did on his street vette and that trans has been together 6 years with a 468 on two stages, 150/300. and it weighs 4020 with him in it (77 with system, iron head and block). some people just abuse trannys though and have bad luck.
    96 c1500, stock suspension, stock bottom end, 93 octane, street radial- 1.60 11.5 at 115- on the small stage-sold
    05 SSS 2wd 228/230/80e/fti4k/5,5drop/215shot-sold
    90 350ss... beast build
