Results 1 to 10 of 10
Thread: UD pullies help please
    Feb 2008
    Arizona
    I called TR to buy some ud pullies and I will get the crank pullie and the belts.. I need to call back to confirm in 15 min... Is there something else I need to get with that?? I have a audio system in my truck that's why he told me not to change the alternator pullie.. Are they worth the money?
    Thanks
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    san antonio, tx
    you'll need a new crank pulley bolt. and a longer bolt would help get the pulley on, but there are other ways.
    2008 Black RCSB Sierra 4.8L
    14.78 @ 90.93 mph
    My Garage
    Feb 2008
    Arizona
    Yeah, it's included on the package bud.. Can I expect around 10rwhp out of the pullie? I'm doing the cam swap at the same time
    Feb 2008
    Arizona
    hey 08rcsb.. I pm you back..
    I know its too late, but you should get the alternator pulley with it. You shoudl go after the 25% UD crank pulley and 23% UD alternator pulley. If you haven't already ordered them, click here.
    Okeechobee, Fl
    Do they really make that .2-.25 1/4 Diff? And or the milage diff?
    49 Ford F1
    I noticed a decent little increase in power. After I installed them, I went out for a test drive and did a 3-1 downshift and it lit up the tires. It used to just chirp them before, but after the pulleys, it smoked them. I am not sure of the mileage, but I can get almost 22 mpgs on the HWY...running 60-65 mph--with 4.10 gears.
    Feb 2008
    Arizona
    I will call tr tomorrow to see if they shipped my stuff out, if not I will order it.. Thanks man!
    Okeechobee, Fl
    Thanx Tyler! If I have any money left over from the rims I might buy a set.
    49 Ford F1
    No prob.
