Results 1 to 10 of 23
Thread: Bad night at SAR!
    Dec 2008
    Del Rio, TX
    Bad night at SAR!
    Well first off, I made it to the track and had a blown tire on the trailer my truck was on(I towed mine because we were picking up my friends s10 so i hitched a ride)
    My first pass went ok but I noticed the truck would rev but wouldnt pull much in the upper rpm(5000 to 6500). 14.1@106 with a 2.5 60ft. Im on 275/55 street tires.
    Second pass, I added 2 degrees of timing on the HP tuner software and removed the air filter to see what would happen. I take off a little harder this time and squeeze out a 2.3 60ft (still slow i know) I notice the truck pulling a lot better than before so i stay in it. At about 200 feet to go BAM!! I hear a horrible noise like I just ran over a large rock. I lift right away and coast through with a 13.6@92mph. Turns out my power steering pump froze and the pulley shattered which shattered my CAI pipe and shredded my belt also.
    Im just getting home at 230am and am shopping for underdrive pulleys and a power steering pump! This bites!
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
    Oct 2007
    Bandera, TX
    that suck about the bad luck, but got some promising numbers.
    single digit street truck
    for build info
    Crossett,Ar
    It could have been much worse. At least they are relatively easy to fix. And if you ran a 13.6 and you let out. You could have put a LOW 13 down easy. A little more tinkering and who knows. If you havent got the tune lined out all the way it is REALLY promisein
    san antonio, tx
    you must have gotten there late?? i was there until nearly 9 and didn't see your truck.
    2008 Black RCSB Sierra 4.8L
    14.78 @ 90.93 mph
    My Garage
    Not too shabby time wise. The boom could have been worse.
    wichita falls, tx
    at least your truck didnt catch on fire....i dont know if i wanna go to SAR or not....everybody is breaking stuff when they go there
    Intro Radicalli's
    southside VA
    that sucks, but it could have been worse!!!
    ff_jeff Guest
    Sorry about your luck. But it could have been worse. IMO people should bring a trailer, a dolly, or at least tow straps to the track. Because $hit happens.
    at least your times were good. Nice MPH.
    damn man that sucks. how long did it take them to clean that up?
    san antonio, tx
    hopefully not as long as a 1/2 track of trans fluid from the S10. i was stuck at the water box for 35 min!
    14.78 @ 90.93 mph
    My Garage
