Thread: light wheels and tires?
    Feb 2008
    Arizona
    I want to upgrade my stock setup but I don't want to lose performance.. I know that's hard to achieve but at least I want to be as close as I can, so I'm asking for you guys help.. My idea is some 20" wheels, and 33" bfgoodrich KM2 mud-terrains.. I know the tires will be heavy but at least I want to get the lightest wheels that I can.. I saw some Diamo wheels that I liked but I'm not sure about that. Please any advice will be apreciated.. Keep in mind that I choose those tires cause I really like their new design AND I do a lot of sand racing..
    Thanks!!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Ft worth tx
    centerline has some really light wheels, but 33" is the max tire size on most. Some of the boss wheels are really light too i just picked up a set of 22's that each wheel weighs 38.5 lbs .
    2004 Gmc VHO (LQ9), AEM cai, perma cool e-fans, aero turbine 3535,obx lt's,undedrive pulley w/overdrive alt pulley, lingenfelter 160 t-stat, zippy tune, taylor 10.4mm wires, tb bypass, Transgo HD-2 c, corvette servos, sonnax accumulator piston's,2600 stall,30,000 trans cooler lowered 1.5"/2", boss 313 22's on 285/45's, rollpan,shaved tailgate w/ss spoiler, painted interior, 2 solo l7 12's,custom fiberglass box,Pioneer F-900 Navi,SSS gauges,billet shiter and pedals,hid's (low's and fogs).
    Quote Originally Posted by GMCvho View Post
    +1. My Centerline Stingray III Ultra Lites are about 24 lbs each--one of the lightest wheels out there. Look at Centerline Wheels for some good choices...
    Feb 2008
    Arizona
    how much does the factory wheel weights? (17" wheels) with lightweight wheels, does my performance will drop a lot?
