Thread: New best 13.2 @ 100.5mph
    Nov 2004
    Pleasanton, TX
    Thumbs up New best 13.2 @ 100.5mph
    Ran the truck at SAR last night after getting my turbo and all the other goodies installed last friday. Ran a new best for me 13.2 @ 100.5mph with a 1.899 60 foot. I knew the truck was running good but damn, I didnt expect low 13's. Got a little anxous at the line on that run, red lighted I didnt get to line up with anything cool, a stock dodge dakota both times I ran. The second run was a 13.4 didnt get as good of a launch. Anyway, I wanted to run some more but they wouldn't let me because I didnt have a helmet. David did let me borrow his for one run, appreciate that bud. Was nice meeting ya and hanging out. I wanna go again and spool up the turbo more on the line, even if I gotta wait until after the lights to launch and see what she does.
    Heres a pic of the timeslip, im number 30 on the right lane.
    2006 K1500 Vortec Max CCSB 6.0 4.10's, Nelson SD Tune, Trick Turbo kit T76 @ 10psi, 60lb/hr injectors, 4" duramax exhaust, snowmeth stage 2 kit, FLT Level 5 4L70E, Vig 2600, 40K trans cooler, 265/70/17 BFG All Terrains. 13.0 @ 102mph 1.8 60ft
    Jan 2006
    That is great times with that heavy truck. Keep it up and you will be in the 12's!
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Nov 2004
    Pleasanton, TX
    Yea I know man, I think I can get a 13 flat if I spool the turbo more on the line. Gonna do a cam and a small shot of nitrous before too long, should put me in the 12's.
    Oct 2006
    Wichita Falls Tx.
    Congrads on the times, should be alot of fun. Cam and nitrous no problems getting into the low 12's. depending on the amount of juice you use. Check out one of our nitrous gauge. P guage could take the place of one of your and still show you the same data.
    Rick
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
