Results 1 to 10 of 18
Thread: Whats up every body!!
    Aurora, CO
    Red face Whats up every body!!
    I'm a newbie from aurora Colorado, i look forward to talking with all of ya! I have a 07 Silverado classic, 4.8L, standard cab, short bed,4x4. Getting ready to install a Magnacharger, LT headers, off road Y pipe, flowies with x pipe and turn downs,comp xr281hr Cam and valve springs, comp roller rockers and get a tune here in the next few monthes!! Should be fun. Any input would be great!! I also have a 89 mustang coupe with a 4G63 (MITSU 2.0 turbo) RWD conversion currently at 682rwhp at 5200 ft of elevation with a curb weight of 2300 lbs!! Don't give me any **** i know its a weird combo LOL. Will see what she runs this summer when the track opens up! Also trying to finish up a father son project, 55 chevy two door post fully tubed and caged with a 477 big block, muncy trans and a narrowed 9". Like i said look foward to meeting all of you and thanks for having me!!
    07 4WD SCSB, LQ9/LS3 w/LS7 cam, LS3 intake,built 4l80e conversion,custom rear mounted TC78 turbo setup, ported exh. manifolds, devils own meth kit, WTA intercooler, aeromotive f-pump,True Trac, stock 3:42's, "new design" gray 20" american racing torque thrust ST's, 3/4" drop kit, painted grille, hids, welded roll pan, iss wing, Factory ss front bumper, TBSS SW, custom pioneer/infinity system with 10" JL sub
    Welcome.
    Welcome to the site!! You have a very interesting compilation of vehicle there.
    mesquite tx
    yes like tha truck but would also like to see this "concoction"
    ITS MATT SUCKA
    98 rcsb dd
    abosolutely nothin cept flo
    & Nelson Tune
    lookin for project
    bangbangskeetskeet: how big is it v?
    mean05: about 8''
    txarkitekt: I will drink you under the table!
    casey23 Guest
    I also have a 89 mustang coupe with a 4G63 (MITSU 2.0 turbo) RWD conversion currently at 682rwhp at 5200 ft of elevation with a curb weight of 2300 lbs!! Don't give me any **** i know its a weird combo LOL. U got pics of this??? what is it exactly....... you put a turbo 2.0 from an import in a mustang?? or the turbo from the import on the engine in the mustang... what got the RWD conversion????
    Quote Originally Posted by casey23 View Post
    Casey--the DSM engine was horizontally-opposed with a FWD tranny. He had to adapt the motor to the Mustang's RWD setup.
    Welcome to LS1truck! Damn, that is one helluva Mustang! Weird, but I bet is is fast as chit!
    And I am with Ian--that 281 cam is slightly too big for the 4.8L 4X4. I would not let the duration get any higher than 228 and lift to .53X... I have seen the GMPP ASA cam work well with 4.8L trucks--but a minimum of a 3000 stall is required.
    Okeechobee, Fl
    49 Ford F1
    Aurora, CO
    Smile pics of the coupe
    I will post pics soon, i have to re-size them, its says they are to big to upload. The mustang has a complete swap in the RWD form. Mods include: Custom built RWD conversion Magnus intake manifold, 90mm Accufab throttle body, custom built top mount full stainless turbo manifold, PT-67 ball bearing turbo, 4" exhaust with flowie and dump near rear end, full Aeromotive fuel system, 1200cc Bosch injectors (runs on E85), Electromotive TEC3r engine management, remote mount electric water pump, Buschur racing Mitsu to Chevy trans adapter plate and flywheel, Ati TH350 and 4000 stall converter, custom built solid motor mounts, trans mount and drive shaft. rear end is stock and waiting for spool and axles. Stock 91 2.0 block with a 2.4 mighty max crank that has been knife edged, Crower rods and Arais pistons(2.3 stroker), fully balanced, CNC ported first gen head that has been hand blended by heads by drew, manely valves, forced performance valve train and custom grind cams, BLE solid lifters, custom coil on plug setup with busa coils, 3.5" garret core intercooler with custom end tanks, 3" all aluminum custom intercooler piping, 3 core aluminum radiator, tial 44mm waste gate and 50mm blow off valve. I still need to get my Drag lites, tires and finish building the rear end. Also needs some body work and a paint job but its getting there!! Its been a three year project. And to be honest i really don't care what negative things people think about it so keep the drama to your self, Thanks!
    Crossett,Ar
    Welcome first of all.
    Quote Originally Posted by chargedLQ4 View Post
    Quick section I read here I wanted to ask about. Why would you run a off road Y pipe into Flowmasters then a X pipe? Why not run the LT into a X pipe then to two Flowmasters (or Magnaflows which flow better). And seriously what are the spec of the cam you are looking at a 281 seems really big for these trucks. Especially a 4.8.
    By the way I know the Gen1 4G63 was a beastly motor. It could hold 30 psi stock. (not for long but it would I know retard down the road did it) But why not Build up the 302 if you sank the same amount of cash in that small block you would be closer to 1k on power. I know I use to be a 4 banger guru in my town and Been around Mitsus for awhile.
    Dec 2008
    Del Rio, TX
    Welcome! Ill agree thats a wild setup with the mustang, my friend actually had dne that same setup but he put it in a second gen rx7. Hey if it makes power then roll with with it!
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
