Ok Guys How Much Boost Can These Motors Handle For Instance My 4.8,and transmission?I WANT 10 PSI![]()
Engine no problem.
Gen-III stock bottom ends push 500+ all the time.
Weak leak, as in any stock engine really, are going to be the rods, then the pistons.
Trans aint gonna like boost. First thing I did on my turbo
build up is get a built trans put in.
the motor will be fine ,but the tranny will go soon after,then the rearend.maybe multiple trannies.do yourself a favor and after the first tranny just do a 80 e swap.trust me,at minimum have the tranny built to level 5 specs.
2014 Xsport- 3.5 Eco boost
412 Motorsports
Why can a 4.8l handle more boost than a 5.3l or a 6.0l?
1991 c1500. 5.3l and 4l60e swap in progress, next paint and body.
short stroke and long rod is better for boost then long stroke short rod. its easier on the bearings. its easier to spin a smaller crank higher rpms then a much larger ones.
412 Motorsports
no wonder i have a big azz 3.90 pulley making 5-6psi,i went down to 3.70 making 6-7psi
on some 5.3's i see them with 3.0 pulleys making 8psi
412 Motorsports
What Size Pulley Do You Guys Think I Need To Make 10lbs?im At 6-7 Psi With A 3.70,im Doing A Ls6 Cam This Week.
