Results 1 to 10 of 15
Thread: Keeps Throwing Codes
    Question Keeps Throwing Codes
    WELL I RECENTLY HAVE A MAIL TUNE FROM NP.THIS IS ON MY BLOWN 08'4.8 GUYS,AFTER 3-4 RUNS,ENGINE LIGHT COMES ON.IT BACKFIRES SOME TIMES.I MEAN IT RUNS GOOD,I GET ON IT EVERYDAY,NO KNOCKING OR PINGING.BUT HERE ARE THE CODES-
    Po171-fuel Trim Bank Condition
    Explanation-the Pcm Uses The Oxygen Sensor To Calculate The A/f Ratio Of The Engine.the Computer Has Recognized A Rich Or Lean Condition On One Engine Bank Only.
    Po174-fuel Trim Bank 2 Condition
    Explanation-the Ecm Has Detected A Rich Or Lean A/f Ratio Condition on bank two.
    So should i take it easy for now ,till i get a live tune.what am i risking?
    It's a MAF tune with boost. Those are lean codes for both banks. May need a MAF solution or a SD tune. Anyone else?
    Spring, Texas
    Do you have a wideband? What is your A/F ratio while in boost? Should be 11.5 or lower. Could be O2's going bad...
    Well Im Looking Into Getting The Wideband This Week From Np.
    I Have My Cat Converters Removed,so Allen Deleted All The O2 Sensors .unless They Still Read??
    Spring, Texas
    Did he delete all of the o2's or just the rear's? I would definitely take it easy until you got a wideband hooked up. At ;east then you will be able to see what it's doing.
    Quote Originally Posted by ramair2002 View Post
    im really not sure,ill have to ask him.
    i get on it everyday,wouldnt it have broken already?lol
    Spring, Texas
    I've got a lot of confidence in NP mail order tunes since that's what I had for a year with my set up. The wideband is just to double check and make sure that everything is in check. Since those codes are for being too lean, I would be very careful about getting on it. Just because it hasn't blown yet doesn't mean it won't. What size injectors do you have? Fuel pump? Do you have a narrow band or anything to monitor AFR?
    SAME HERE THATS WHY I WENT WITH HIM.
    I HAVE NOTHING TO MONITOR MY A/F RATIO
    THE INJECTORS,WHATEVER COMES WITH THE 112 RADIX MAGNUSON42-44?
    AS FOR FUEL,STOCK FUEL PUMP WITH MAGNAVOLT FROM CHARGER KIT.
    IM ONLY AT 5-6PSI,IM ALSO RUNNING TR6NGK
    Pittsburgh, PA
    just cause its not broke doesnt mean it wont break.
    IMHO a mail order should only be used as a base
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    UPDATE:
    ill be getting my gauge tuesdaythanks to melissa and nelson performance
