Thread: 15" wheels out back?
    Okeechobee, Fl
    Question 15" wheels out back?
    One of my friends has a set of 15x10 al. wheels that have the same bolt pattern as my truck(6x5.5) that he said I could have. My ? is will they fit over my rear drums?
    49 Ford F1
    15" should fit the '05+ half ton drums.
    ff_jeff Guest
    they should fit, but it all depends on the back spacing.
    Okeechobee, Fl
    They are about 5" of backspacing, But I found out they take mag wheel lugnuts. Do they make big enough mag lugnuts?
    49 Ford F1
    College Station, TX
    Quote Originally Posted by 06 4.8 View Post
    Im sure they do..
    I put 16s in the rear of my truck temporarily and they cleared no problem you should be fine..
    Okeechobee, Fl
    Does anybody know if they make the lugnuts bigenough that are flat on the side that touches the rim(AKA mag lugnuts).
    49 Ford F1
