Results 1 to 10 of 22
Thread: Suspension Guide Lowered/Lifted
    Your Moms House
    Ok so I know one of the most asked question when someone see's a truck on this site is how low is your truck and how did you lower it or how high did you lift your truck and what componets did you use. So this thread will be for every one to post a picture of there truck with a list of componets you used to lower/lift and how low/high your truck is. And if you could post your tire size also. Thanks Ben
    Ill start
    Lowered 3front 6rear
    Beltech coils
    DJM Flip kit
    Falken 275/45/20
    Truck is in sig.
    DJM 3" LCA's
    6" flip kit
    general grabber UHP
    265/55/16
    wichita falls, tx
    djm 4in upper and lower control arms
    djm 6in flip kit
    nitto invo 285/30/22
    after all said and done it turned out to actually drop it 5/7 and i have no rubbing issues
    Mar 2008
    Key Largo, FL
    Truck is my avatar:
    2/4 Drop
    DJM 2" Coils
    DJM 4" Shackel / Hanger
    245/75/16 Dunlops
    2000 GMC Sierra RCSB with a 5.3 and 4L60E. Let the games begin. Started with Camaro E-fans, Nelson Harness, 160* thermo, PaceSetter LT's, Random Tech Cats Hooker Aerochamers and true dual 3" Dumped at the bumper, 2/4 drop, NP performance tune, Built 4L60 and Alpine audio, TR220 cam, LS6 Ported Oil Pump, LS2 Timing Chain, LS2 Lifter trays, Vigilante 3k stall conv., Built 4L60E, 4.11 gears, Detroit Tru-Trac and all of that adds up to no traction and garbage 60' times. What next......?
    http://s466.photobucket.com/albums/rr21/fb9120/
    Okeechobee, Fl
    I know it's much but.
    2" rear lowering shackles
    305/40/22
    49 Ford F1
    College Station, TX
    6" Rough Country Suspension Lift (Cranked to about 5.5")
    3" Performance Accessories Body Lift
    1" Rear Lift Shackles
    (I have a Zero Rate Add-a-leaf Im bout to put in the rear to level it but you could picture it)
    35x12.50x17 Super Swamper SSRs / 17"x9 Moto Metal 951s
    Chandler, Ok
    just 2in shackles on the back....
    My names: MATT
    Drive: 1998 legend conversion silverado
    Status:Married, one gorgeous daughter, mystery baby on the way, and broke! Hopin to find engine soon...
    shirt size: Medium
    Truck pic in sig.
    Stock suspension (Z85) in front
    2" Leveling shackles in rear with stock leafs
    Monroe shocks
    275/45/20 Sumitomo HTR Sport H/P
    Feb 2008
    front
    2" belltech spindles
    3" belltech springs
    rear
    6" DJM flip kit
    2" DJM shackles
    275/45/20 toyo proxy S/T
    04 RCSB- 4.8- bolt-ons..nuff said
    carbs are for salads and lawnmowers,
    Aug 2004
    Magnolia, TX
    2006 RCSB/2WD
    2" Belltech Coils
    2" Shackles
    2" Hangers
    removed overload
    275/60/17 Falkens
    2004 ECSB/2WD
    4" Sprintech spindles
    2" Blocks
    265/70/16 Goodyear Wranglers
