Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 67
Thread: truck wont start
    Thumbs down truck wont start
    i just finished my all my wiring and the truck wont start. all the relays are clicking the fuel pumps is working the injectors aren't clogged. if i spray starting fluid in it and crank it it sounds like fires 3 or 4 times and then nothing. i pulled the plugs and they're wet and smell like gas. however when i cranked it with them out i didn't see any spark. but every time i crank it it looks like a little bit of smoke comes out of the manifolds. im at a complete loss here i had vats removed in the tune. if i turn it on the the throttle body opens and closes like it should so that means the ecm is working right (its dbw). any thoughts on anything i should check im really at a complete loss here.
    Mar 2006
    Phoenix, AZ
    You sure you got all of the grounds attached right? That's usually the culprit with a crank but no fire condition after a motor swap.
    I want to say that there are 3 on the back of the block and two on the driver's side.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    hmm i only saw 2 coming out of the engine part of the harness and on near the ecm. i guess ill have to snoop around for some more. also besides grounds, the 12 volt constant and switched wires and the fuel pump is there anything else on the harness that needs hooked up
    Oct 2003
    Grounds...
    Engine to frame, engine to battery, battery to frame, harness to engine, harness to battery. These computers are very "ground" needy.
    Kentucky
    there are 2 grounds on the rear of the engine and 1 ground close to front drivers side coming out of harness.
    I'm assuming your not getting any codes.
    1996 GMC extended cab, 2003 5.3/auto
    Mar 2006
    Phoenix, AZ
    Quote Originally Posted by 468Blazer View Post
    There are actually two that bolt to the driver's side of the block down low. One comes from the engine harness, the other is the battery ground.
    yah i have all the chassis grounds (engine to frame, battery to engine, and cab to frame) and then three off the harness one near the ecm an two on the engine) anything im missing? also besides besides 12volt switched and constant are there any other wires to hook up the starter is basically hot wired right now im kinda thinking vats isnt deleted
    one below the power steering pump on the side of the block.
    that one goes to the battery right because i have that hooked up. i should of just sent my harness to you guys
    Mar 2006
    Phoenix, AZ
    There's another one that goes there too. Like I said, battery ground and also one from the harness. Both go to the lower driver's side behind the p/s pump.
