Results 1 to 10 of 10
Thread: dropin a 4wd
    Butler Ky
    dropin a 4wd
    Guys im lookin in to lowering my truck and i was wondering if u guys would post some pics up and sayin what kit u got.
    Thanks in advance
    -Nate
    76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
    Southern WI
    I've only got a partial kit on mine...first remove the blocks in the back, free 2" down and uncrank the torsion bars as low as they go, about 1-1.5" down in the front...next for the back the easiest is to get the shackles whick give you 2" more on the lowest point. i'm planning on buying 3" drop spindles in the front and possibly doing the hangers in the back to get in pretty close to the ground. Make sure you get it realigned if you mess with the bars, or anything in the front for that matter. Good luck!
    Mike
    2000 RCSB
    Red Deer, Alberta
    I'm sorry but 4wd's are to be lifted not lowered.
    So Cal
    my Z71 had drop shackles, i removed the blocks and lowerded my torsion keys as far as they can go and it looks sweet but recently i bottomed out and im kinda screwed =)
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Quote Originally Posted by Felix 89 View Post
    :bsflag:
    Butler Ky
    :wtf:
    newburgh, NY
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Collection of Lowering Notes and Best Practices - SilveradoSS.com
    this is another good link.
    Truck - 99z71#
    Truck - DSC09691
    pics above are before and after removing 2" blocks and mcgauhys 2/4
    With helper air bags making it level.
    Butler Ky
    thanks for the replys guys!! Zeake that is how im wanting my truck to sit and i am going to be getting the tahoe 20's. What size tire are u runnin and does it rub any.
    Also does any one know how much tahoe wheels weigh???
    Thanks guys
    Nate
    I am running a 295/45/20 and am looking at new tires. Something a little taller to soften the ride. The 295s never rub and are only 30.5" I think I am going to go 305/50 which is 31.9. I think it wont scrub. Keep in mind my helper airbags in the back. They add 3" to the rear at about 35lbs of pressure.
    The link below has some pics with the rear bags empty. they are slam air bags from summit and you have to have the ones for lowered trucks or they won't fit. I also have limiting straps to keep the bags from being damaged if the rear is lifting by the frame instead of the axle.
    Putfile Photo Album Detail - Truck
    you can via the link see my whole truck album of pics from way back when i first bought it.
