Results 1 to 10 of 24
Thread: Dynotune nitrous kit, HSW plate, heater, FPSS, window switch...
    Jul 2007
    Cedar Park,TX
    I have a complete nitrous kit for sale. Here is what is included.
    Dynotune nitrous kit $379
    camaro & firebird wet Nitrous Oxide Sysetm for camaro & firebird. Wet Nitrous oxide system for camaro & firebird ls1 ls2 ls6 ls7 engines. camaro & firebird nitrous systems avaiable with diffrent jetting levels. - ls1 camaro and Firebird Wet Nitrous S
    Dynotune liquid filled nitrous bottle gauge $24.95
    DynoTune Product, 910-Liquid Filled Nitrous Pressure Gauge 1.5" - DynoTune, Nitrous systems, Purge kits, Nitrous Bottle heaters and more!
    Dynotune digital two stage rpm window switch $129.00
    Digital Two stage rpm window switch with built in TPS switch for nitrous oxide. Nitrous oxide rpm window switch at discounted prices. Controls two stages of nitrous oxide. - Digital Two stage rpm window switch with built in TPS switch for nitrous
    Dynotune pruge system, I replace the cheap tubing with a piece of stainless hardline. $59.99
    Nitrous Purge systems that purge Nitrous from the Line, reducing ET. Nitrous purge kits and systems purge nitrous into the air making max HP. Dual outlet purge kits with large solenoids. - Nitrous Purge systems that purge Nitrous from the Line, reduc
    Dynotune fuel pressure safety switch. $39.95
    Fuel Pressure Safety Switch for Nitrous Oxide FPSS. If your fuel pressure drops it will shut down the nitrous oxide system and save your engine. - Fuel Pressure Safety Switch for Nitrous Oxide FPSS
    Dynotune High output (black) bottle heater (adjustable) this thing is SUPER fast. $110.00
    Nitrous oxide bottle warmer kits for 10oz to 10lb nitrous bottles. Nitrous bottle heater will keep the pressure steady making more HP. Warm that nitrous bottle with high temp nitrous oxide bottle heaters and warmers in orange and black colors. - Nitr
    HSW plate conversion kit, all jetting included from 75hp to 150hp. If you have a cable TB I will even include the bracket I made to re-locate the throttle bracket forward one inch, no one even makes these. $209.99
    Harris Speed Works :: EFI Nitrous Kits :: HSW EFI Wet & Dry Nitrous Plate Kits :: EFI Wet Nitrous Plate Conversion Kits :: HSW 78mm Sudden Impact EFI Wet Nitrous Plate Conversion Kit (78mm LS1 F-Body | GTO | CTS-V | Truck Platforms)
    This is a COMPLETE kit, hook up a couple of wires and run the line to the bottle and you are good to go. I have not had one single problem out of this setup, it works fantastic. I have left all of the wiring connected with every connection marked for SUPER EASY installation. I had the bottle mounted under the center console, switches were above the air bag key hole, and the solenoids were mounted under the engine cover, if you want to mount it all the same way everything is the correct length and ready to go. If not just lenghten/shorten the marked wires, its that simple.
    I purchased everything brand new less then a year ago and with no shipping I paid $952.88 for all of it.
    I am willing to let it all go for $750 + s/h. PRICE LOWERED $650.00 Shipped.
    Thanks
    -Chris
    01' 2500HD 4X4
    6.0L 4l80E
    stock....
    -Chris
    Jul 2007
    Cedar Park,TX
    $750 shipped??
    01' 2500HD 4X4
    6.0L 4l80E
    stock....
    -Chris
    Mar 2006
    would you be willing to seperate the heater?
    Apr 2005
    springfield MO
    that is a nice setup...
    1968 Chevy SWB Fleet. 2002 5.3 all stock (for now ) Nelson Tune 4l60e w/TB converter.
    ok not stock anymore...13.3 at 101
    Now with front mount turbo... new times soon
    Jul 2007
    Cedar Park,TX
    I am open to offers.
    01' 2500HD 4X4
    6.0L 4l80E
    stock....
    -Chris
    Mar 2006
    Quote Originally Posted by 85mudblazin View Post
    Is this kit still for sale?
    ff_jeff Guest
    I still want the plate Chris.
    Oct 2007
    Bandera, TX
    this would be nice so get me off the line....... lol, or just make it spin more...lol
    single digit street truck
    for build info
    Aug 2004
    Magnolia, TX
    could you find out how much shipping would be to 09469? very interested!
    Jul 2007
    Cedar Park,TX
    Quote Originally Posted by 2k5Squirrel View Post
    Sure, what carrier should I use?? Will UPS deliver there??
    01' 2500HD 4X4
    6.0L 4l80E
    stock....
    -Chris
