Results 1 to 10 of 23
Thread: overheating issue
    Aug 2003
    Spring, TX
    Thumbs down overheating issue
    yesterday as i was sitting at a light, in traffic, i glanced down to see my coolant temps a lot higher then usual.
    the guage didn't hit the red but had i sat there a little longer it probably would have.
    so once i seen it i turned off the a/c, turned into the the u-turn lane and went into the nearest parking lot.
    but even before i got there the gauge dropped back down to normal driving temps.
    i put the truck in park and i sat there for a moment, then raised the hood, no steam coming out, to see if could see a leak or anything.
    no leaks or anything.
    get back into the truck and get on my way.
    i left the a/c off and the temps never raised again.
    a guy on another forum said something about checking my wp but how do i do that?
    but would it even be that if the temps stayed down after turning off the a/c?
    btw, i still have the clutch fan.
    maybe my fan clutch is going out?
    i've replaced it once already with a used unit and never had temp problems until now.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    Southeastern Wisconsin
    ya thats an interesting problem, might possibly be a fan issue. not sure really, i have e-fans so one is on constantly when the A/C is turned on.
    I'm sure someone on here can tell you how to check that.
    Otherwise its time to get E-fans and call nelson performance up.
    how hot out was it when this happened?
    1999 GMC Sierra SLE ECSB .... 5.3L w/ Slight Performance Tune / True Duals with Flo Pro Glass Packs.
    Project ''Bad Company'' Future = 6.0L (Forged Internals) / Boost (TVS) / 4L65E LvL 5 / AWD Conversion / Full LT's with Cats / Methanol Injection / Lowered 2" / SS Rims / Frame Up resto
    Officially Employed!!!
    Aug 2003
    Spring, TX
    Quote Originally Posted by 99sierra4x4 View Post
    my mirror temp was changing between 101 and 97 degrees
    -leo-
    what mods do you have? i am fully bolted with H\C with e fans, sat in traffic today cause of a accident up the road sat for like 10 to 15 minutes before i decided to turn truck off temps came up to 230-240 decided to start truck back up to see how high the temps would rise, well it never passed the 240 mark.. but once i started moving temps went back down, remind you i have NO ac, lmao and it was freaking hot this morning..
    Simple: 408 on steroids!
    single digits coming soon!
    Aug 2003
    Spring, TX
    cammed w/ cai, pulley, exhaust
    -leo-
    Racoon Twp., PA
    Don't the pulleys slow down the water pump?
    2013 CC 5.3
    81 C10 LS1 project
    Aug 2003
    Spring, TX
    only has a crank pulley so i don't know if it slows down the wp.
    -leo-
    Since everything runs off the crank pulley slowing it down slows everything down.
    Aug 2003
    Spring, TX
    i thought that a smaller pulley would speed up the crank????
    drove the truck in this morning w/o problems.
    the only thing is it wasn't as hot outside as it was that day.
    so this afternoon we will see how it handles the heat.
    -leo-
    Apr 2006
    Bellevue, Nebraska
    That happened to me at about 130k miles and it turned out to be blockage in the Radiator. Maybe hit it with a heat gun and see if yuo get any hotspots. Mine would only get hot at hwy speeds and only on some occassions.
