Thread: What gear oil
    Oct 2007
    weatherford,TX
    What gear oil
    i got my rear end back from fort worth gear and axle friday they put the tru trac in but did not put any gear oil back in its dry what do i need to run in it, they said to change after the first 500 miles
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
    san marcos,tx
    SAE 75W-90 Synthetic Axle Lubricant , not sure if you need to run any friction modifier in since its not limited slip.
    Jun 2007
    my eaton said dont use synthetic,but to use 75-90 with friction modifier.tru trac is owned by eaton,so im thinking could be the same.
    May 2007
    Prairieville, La
    eaton also says not to use synthetic or any modifier with the tru-trac. a few guys on performancetrucks.net had there's only pulling one wheel. took the synthetic out after a call to eaton and that solved the problem.
    04 GMC Crew Cab 6.0 TR224 3000 Yank Pacesetters W/ ORY TBSS Intake UDP CAI Blackbear Tuned
