Results 1 to 10 of 18
Thread: If you need paint and body help!
    I am new on here but my expertise is paint and body, collision repair, restoration. Not to toot my horn but I am capable of doing anything...almost! LOL! I do collision and restoration. As of lately more restoration it seems like. Have quite of few projets in the shop. Sooo, if any of you guys need help like some of you have helped me so far with mechanical questions I can be your guru and help. Feel free to ask me for any advice any time. I will be more than glad to help. Overyspray removal products, buffing, paint, body, primer, paint and material questions. You name it. So far everything that has been built out of my shop has taken first place. Some best of shows and some peoples choice awards.
    got any pics of your work?
    Yes I do, let me see if I can figure out how to post on here for you guys. Okay I figured out how to do it, I just need to resize my pics.
    Wow, I have resized the pics to the point where you could barely see them. Any suggestions? Maybe host them to imageshack?
    Well, I have tried to post pics both ways and neither work. Sorry guys.
    Oct 2007
    Bandera, TX
    i need to buff and maybe wet sand my truck, have alot of light scratches and swirls and overspray from the previouse owner. any suggestions?
    single digit street truck
    for build info
    Yes, let's try the conservative approach first and then we can go to other measures. I suggest you purchase some "clay magic" which will be a blue clay bar along with the "Lubrishine". Spray the Lubrishine on there first and then rub with your clay bar. The bar will start to look dirty. Oh, make sure and wash your truck first real good. Then clay bar. When you are done go over the truck with "butter wax". That should make your truck look like a million bux. If that does not work than you will have to buff with a buffer with machine glaze on a black 3M foam pad. Let me know how it turns out.
    Oct 2007
    Bandera, TX
    Thanks,where would i get the clay and lube?
    for build info
    Try your local auto parts store, o'reily's, or if not a paint store. Either one should have it. If that does not work for you than you will have to buff.
    Let me see if I can load a couple that I found that are under the 97.7 requirements
    Mar 2008
    Pearland,Tx
    hOW MUCH TO PAINT MY DOOR HANDLES? tHEIR PLASTIC ONES?
    2008 GMC Sierra 5.3
    RCSB
    K&N Intake,Flomaster Dump,3.73,g80
    Comming soon :Cam ,Nelson Tune, LT Headers and the works.
    Okay I think I have this figured out on the pics of my work, I just wish they were larger to show more detail.
