Results 1 to 10 of 11
Thread: Starter wires
    Kentucky
    Starter wires
    On the 5.3 starter there are 3 posts on the starter. With engine in truck. The biggest post closest to frame goes to battery hot. The small post on solenoid goes to ignition. The big post next to engine whats this go to? Is this a ground? I was thinking it was a ground but on the old 5.0 starter there are only 2 posts (hot wire and solenoid)
    Thanks
    Travis
    1996 GMC extended cab, 2003 5.3/auto
    Should just ground to the block right?
    I checked autozone repair. They gave a torque spec for the positive battery cable to starter connection, no others listed, so im gonna go with no.
    LSX conversions, so easy a caveman can do it.
    May 2004
    DO NOT!!!ground the starter to the block. The negative battery cable should go to the block by the starter and the large post closest to the frame is the positive battery cable. The purple wire goes to the starter relay. The starter is grounded when bloted to the block.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Should ground to the block = grounds itself when bolted to the block.
    May 2004
    Yep, I might have misinterpreted your statement when he posted "The big post next to engine whats this go to? Is this a ground?" and you posted "Should just ground to the block right?".
    97 GMC, 2002 LS6.
    Ero in treno da Roma a Sassari e mi stavo annoiando, così ho cominciato a cercare notizie locali sul cellulare. In quel momento mi è comparso http://marghinenews.it. Ho iniziato a leggere articoli sulla zona del Marghine e sulla vita nei piccoli centri dell’entroterra sardo. Mi ha sorpreso la varietà dei contenuti, che non parlavano solo di cronaca ma anche di cultura e tradizioni. È stata una compagnia interessante durante il viaggio, e alla fine ho salvato il link per tornarci in seguito.
    There is not supposed to be anything hooked to the 3rd post. Forget it's there.
    Jun 2007
    maine
    exactly!
    May 2004
    x3 - I should have stated that also.
    97 GMC, 2002 LS6.
    Kentucky
    gotcha ya. Nothing hooked up to the 3rd one.
