Results 1 to 9 of 9
Thread: Auto Meter Gauges
    Mar 2008
    Austin, Texas
    Auto Meter Gauges/Door Panel/Sub Box
    Used set of Auto Meter Gauges
    Ultra-Lite Trans Temp $30.00
    Ultra-Lite Air/Fuel Ratio $50.00
    Ultra-Lite Volt Meter $30.00
    All three for $100.00. Make me an offer!
    All three gauges are 2-1/16" in size.
    Gray 2007 Door Panel with crack on inner side near window. Will fit 99-06 + 2007 Classic GMC Sierra and Chevy Silverado Extended Cab Trucks. See photos below. Asking $20.00 OBO.
    Barely used Pro Box for extended cab Chevy and GMC trucks. Fits two 12" Subs. Wires already soldered to outter connectors. $75.00 OBO.
    http://www.ls1truck.com/upload/files/116/Sierra%20007.jpg
    2007 GMC Sierra Classic 1500, Pioneer D3, JL 450/4, JL 500/1, JL W3, Focal K2 6 1/2Comp, K&N 77 Intake, 160 t-stat, Flowmaster cat back, Airaid tbs, and Superchips.
    2006 Chevy Silverado 1500 RCSB Z71 5.3L, 3.73, K&N 77 Intake, Flowmaster dumps, Pioneer D3, Focal A1, JL 300/4, JL 500/1, JL 12W3.
    Thinking about trans temp. Gotta have money first
    Jun 2007
    do they all have the proper connections to hook em up.?
    Mar 2008
    Austin, Texas
    I should have everything that came with them new. I will let you know!
    Feb 2005
    Interested in the trans and volt gauge if they have all the hardware and enough wire to tap into.
    Mar 2008
    Austin, Texas
    Quote Originally Posted by YenkoST View Post
    Should have all the hardware. Has plenty of wire to solder onto.
    Feb 2005
    No stratches correct?
    Mar 2008
    Austin, Texas
    No stratches, the gauges look brand new!
    Mar 2008
    Austin, Texas
    All three Auto Meter Gauges sold! Still have sub box and door panel.
    Thanks
    Allen
