Thread: rear brake clunk
    Oct 2005
    rear brake clunk
    Over the past couple weeks the rear brakes have begun making a popping sound (clunk) when braking to a stop. I don't notice it at speed, just when I cam slowing to stop.
    I can also feel the pedal pulsing slightly in connection with the popping.
    Pulled the drums off the other day, and nothing looked out of sorts.
    No broken or cracked shoes, or drums.
    Any suggestions?
    92 fullsize with 4.56 gears eaton limited slip, stock rear drums and relatively new shoes.
    Stops good, just sounds bad, and feels a little concerning under my foot.
    Thanks in advance
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
    Uvalde
    If your hearing a clunk in the rear that sounds like the leaf springs are popping or the brake shoes are sticking, I recommend you remove your driveshaft and grease the inside splines if the input yolk, what happens is that the yolk no longer slips in and out of the trans output shaft, and when you brake the rear of the truck comes up extending out the shaft, then when the weight comes down the shaft travels back in and binds making the popping sound like a clunk, that's what I have ran across many time at the dealership I work at, wont hurt to look at that possibility, let me know what you find out...
    Had a 99 GMC ESCB with LQ4 conversion and Nelson Performance tunning, currently workin on my 82 SCB GMC with carbed LQ4 conversion in progress, Also have a 00 SS Camaro that runs mid 11's all day long with bolt ons, Drag race my 79 malibu that has a 496 BBC runnin 10's on motor, shootin for 9's with the 250 shot of nitrous in its near future. Use my 04 2500 chevy to pull my rig around and drive the fam in our 07 NNBS yukon, Die Hard Chevy Fan Till The Death.
    Oct 2005
    Thanks, I will give that a try.
    The tranny was out not too long ago, and everything looked good with regard to lubrication on the splines, but I'll check none the less.
    Also could that explain the pulsing feeling in the brake pedal?
    Thanks again.
    Wasilla, AK
    Quote Originally Posted by BossGMC View Post
    X2
    Hutto TX
    Did it start to happen only after you did the rear brakes?
    Is the smaller shoe installed towards the front on both driver and passenger side?
    If not, it be catching on the larger shoe and actually pulling it down on the mount(and extending the wheel cylinders letting your pedal go down) and letting it *bang* back into place when it physically can't rotate the shoe any further in the drum(and pushing BACK in on the brake cylinder, making your pedal go up) Small shoe should be towards the front of vehicle.
    1991 Silverado ECLB
    LM7-T56
    Oct 2005
    Thanks,
    I have not had a chance to work on it tonight, but will get to it tomorrow, and let you know how it goes.
    It did not happen soon after the brake work, but it is possible that I got the shoes switched.
    I will check out the advice tomorrow.
    Thanks guys
