Results 1 to 8 of 8
Thread: CRANK CASE VACUUM SYSTEM for turbo?
    Any one ever used one of these systems? If so how well does it work?
    ET-Performance & Racing Products - Automotive - "Turbo Kit" for ALL Auto Engines
    I have just installed a trick turbo. I drilled a hole in the oil filler cap and put a filter on top of it.
    Well it blew oil all over the engine. I replaced the cap and you should see the smoke the truck makes. Not to mention my spark plugs have got to be oil fouled. My truck died in the driveway today. I was so glad to be at home where I have no tools at all. All my tools are at work.
    I thought about the ls6 valley cover conversion but that looks like a huge pain in the arse.
    Some one please lend me your knowledge. I need my truck back in operation. I can't haul off the trash return the work trailer back to work etc etc etc.
    Oct 2006
    Wichita Falls Tx.
    The vent on the passengers side, route a breather from it. Start the truck, does it have a large amount of blow by.?
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    So cap it on the manifold and put a breather on the drivers side?
    Jun 2007
    thats what i did
    Oct 2006
    Wichita Falls Tx.
    cap on manifold?
    you lost me.
    I took the hose that went from the passenger side vavle cover to throttle body. I capped the t-body port and installed a small breather filter on the hose. And just zipped tied it up.
    pcv stayed in place.
    Online Store
    [/CENTER]
    The vent hose on the back of my drivers valve cover goes to the top of the intake manifold. Looks like the manifold pulls from the back of that valve cover and also the passenger valve cover. I'll take a picture and post it later. My wife is on me about her honey do list.
    Jun 2007
    you can cap the manifold for the drivers side and install breather were the pv c is or use an catch can ,and like turbo said about tb ,cap it and either run it too catch can or install a breather on it .
    Jun 2007
    turbos just saying he installed a small breather to the line coming off the valve cover on the pass side.
