Results 1 to 10 of 12
Thread: relocating the mass air?
    Jun 2007
    so my iats are climbing with this 90 dg weather.my current location is were the factory box was .i would like to move my intake to a more ideal place ,and it doesnt lok like the harness for the maf is long enough to put in front of the tb.do you guys have to lengthen the wires when you relocate them or am i just misjudging the lenght of the factory harness?and were is the most ideal place to install the intake tube and filter ? iwas thinking straight down too suck outside air going down the rd.im open for ideas.or pics would help.finally ,my factory maf bolts to a shield then a 5 inch filter.if i illiminate the 5 inch filter ,will i just go get a smaller 1 or is theyre something else i have to do?aanother words were it sandwiches together ,is there a lip fo a smaller filter or is it just a butt thats adapts from maf to 5 inch filter .i hope this makes some sense .seems rediculous but thats what im looking at on my setup.
    Jun 2007
    bump.
    I'd look at 04chase on silveradoss.com he has a vortec and might have some pics that would help you out.
    Sallisaw OK
    i just extended the wires on my MAF and no problems at all.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Jun 2007
    Quote Originally Posted by 567234ta View Post
    thank you 2
    newburgh, NY
    when you did this did you just basic cut the wire and solder in extensions?
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Sallisaw OK
    Quote Originally Posted by trx2stroke4life39 View Post
    yes thats exactly what i did.
    6.6L 4l80e
    MY GARAGE
    Jun 2007
    yeh thats right he has a sweet setup.thanks
    Mar 2006
    Mesquite
    Mine reached fine without cutting it. Just pull it out of the wire loom and it will reach over.
    newburgh, NY
    Does it matter how close the maf is to the engine? So if i were to to move say 2 feet would it matter?
    Step 1. crus at it.
    Step 3. torch it.
