Results 1 to 7 of 7
Thread: Polishing plastic
    Eastern Idaho
    Polishing plastic
    Okay, so I pull the bow-tie off my grill last night and clean it all up to paint it. The outside/front looks like someone tried to buff it with a fine grade steal wool so it has a flat finish not a glossy one. Is there any way to polish that up or am I S.O.L.?
    Sallisaw OK
    depending on how deep the scratches are on it you could use fine sandpaper, like up to 1000 grit then rubbing compound, a coat of wax and it should be pretty glossy. i need to do that to my mirrors.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Eastern Idaho
    Quote Originally Posted by 567234ta View Post
    I'll give that a shot. I just bought a bottle of Meguiar's dual action polisher to take some swirls and scratches out of my paint, if it's safe for plastic I'll bet I could use that. If it won't mar clear coat it shouldn't make the plastic worse.
    Thanks.
    Mar 2006
    Mesquite
    Or you could just paint it. Krylon Fusion works really good on plastic. I forget what color your truck is...
    Eastern Idaho
    I painted the back so I'd like to get the front looking good if I can.
    Eastern Idaho
    I used 1000 grit wet/dry sand paper then took my orbital buffer and Meguiar's #83 Dual Action Polisher to it. Maybe not showroom new look but da 'Ho is a 2000 and I'd say it looks like what you'd expect for an 8 year old ride. Maybe I'll try and post up a pick when I get it put back.
    Eastern Idaho
    If ya wanna see how it turned out follow this thread.
    http://www.ls1truck.com/forums/appea...if-you-do.html
