Results 1 to 2 of 2
Thread: 5.3 to 6.2 swap?
    Feb 2006
    MIZZU
    5.3 to 6.2 swap?
    Do I need a different wiring harness and ECU to swap a 2007 escalade 6.2 into a 1999 Silverado with the 5.3? I know the 6.2 has varible valve timing but can that be deleted with a cam or valvetrain swap??
    I was planning on a 6.0 swap but i found an awesome deal on a 6.2 engine with no harness or ECU.
    Let me know.
    Thanks, TY
    1999 Silverado Z71 RCSB with 2006 LQ4 6.0, Comp Cams 220/220 581/581 115lsa, STS, methanol, Nelson street tune, 160* stat, 2006 E-fans, FLT 4L60. 12.53 @ 107 on 5psi
    Yikes... I am sure you will need a new wiring harness and PCM (ECU). The NNBS trucks are different than the NBS trucks when it comes to the wiring.
    As for the VVT stuff, I would have no clue...sorry man.
