Results 1 to 8 of 8
Thread: Duramax stuck in 4 low
    Oct 2007
    Bandera, TX
    My truck is stuck in 4low, anyone have any ideas?
    single digit street truck
    for build info
    Oct 2007
    Bandera, TX
    got it out finally,,,,,, something definetly wrong. First time I used 4 low since the new tranny. I will be getting it checked out...
    for build info
    The G spot in Gaskin, Florida
    Probably the encoder motor, or do you have the stick in the floor for the t-case?
    Also how many miles are on the truck?
    Look for the pump rub hole on the t-case, it is a common problem.
    I see you have the 2007 model, is it the NBS or the classic?
    I will be out of town starting in 30 min. until Sunday, so if you need any help with this, I can get you going in the right direction, I have some knowledge of those New Process 261-263 Transfer cases.........
    2006 1500 CC/SB with the 5.3L and Nelson PCM.
    soon to come is a intake and exhaust. (wifes truck)
    Other vehicle is a 03 2500HD CC/SB 6.6L DMAX straight piped and Edge stacked with Superchips and gauges, Loves to eat rice for sure! Fartcan exhaust makes it better!
    Oct 2007
    Bandera, TX
    Ya, I checked the fluid, its good, Its the electric t-case, Classic with 21000 miles. I will be getting it checked at the dealer on monday. Thanks,
    for build info
    Quote Originally Posted by Tolliwacker View Post
    Probably the encoder motor...
    Yeah, it is either the Encoder motor or the Encoer switch inside the motor. It is usually the Encoder switch. GM trucks have this issue quite often for 4WD trucks. And if it is the pushbutton 4WD, then sometimes the dash mounted switch goes out, but that rarely happens. Did you get a "Service 4WD" light on the Message Center on the dash?
    Oct 2007
    Bandera, TX
    no, no message or code. The dealer changed both the parts you mentioned, along with alot of other parts inside the t-case. they think it is in the tranny, Im talking with Casey23 now about what possibly it could be, it just started after the suncoast install. No fix yet though
    for build info
    newburgh, NY
    stupid question. were you in neutral when it didn't come out of 4low
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Oct 2007
    Bandera, TX
    Ya, N, D, R. Tried them all. I know it needs to be in neutral, Its going to the dealer on monday for service.
    for build info
