Results 1 to 10 of 18
Thread: a/c short cycle
    wichita falls, tx
    a/c short cycle
    any one know what will cause the a/c compressor to short cycle?
    the compressor stays on for like 5 sec and then turns back off for bout 7 sec
    02 silverado 5.3
    Intro Radicalli's
    Hutto TX
    A low charge of freon would do it.
    1991 Silverado ECLB
    LM7-T56
    Wasilla, AK
    Quote Originally Posted by r6z4o6 View Post
    x2 Low charge. Have the leak found and repaired. If you bypass the low pressure switch to make it run anyway, it will damage the compressor.
    Mar 2006
    Phoenix, AZ
    Is the air still cool? If so it's probably normal.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    wichita falls, tx
    this is the first time i have used it since the 5.3 swap. the low pressure side is fine...someone else said it was the orfice ttube...what ya'll think?
    Intro Radicalli's
    Wasilla, AK
    The oriface tube is basically just an inline filter, after the compressor. It should be okay unless your compressor is coming apart, filling it with metal, and plugging the line. What you described is exactly what happens when your refrigerant charge is too low.
    wichita falls, tx
    k...ill double check it thanks...what should the pressure be on the low side (round about figure?)
    Intro Radicalli's
    Don't know--but you can go to your local auto parts store and buy a R134a recharge kit to where you can charge it yourself. Make sure to buy a setup with an inline pressure gauge--and follow the directions specifically.
    wichita falls, tx
    my buddy is a mechanic and has all the gauges and stuff...i was just looking for a estimated number of what should be in there and ill compare that to what is in there now.
    Intro Radicalli's
    IDK about the psi...35-40psi maybe??? Also, a low charge of freon can cause the "short cycles," but typically the main cause of the short cycles with the compressor is the Pressure switch...
