Thread: AC bypass
    Crystal Lake IL/ Houghton MI
    AC bypass
    has anyone bypassed there AC pump on a gen 3 if so how did you do it?
    Mar 2006
    Phoenix, AZ
    Why would you bypass an A/C compressor? Just remove it.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    Dec 2003
    Azle,TX
    It has a seperate belt.....just take it off
    Vortec Performance Tuned
    Quote Originally Posted by COWL327 View Post
    i did not know that, i guess i should wait until i actually have my engine in hand to figure this stuff out
    Jun 2007
    yup, just take the belt off ,then if you get tooo hot down the rd you can just put it back on.
    Quote Originally Posted by Ramsey View Post
    yea i won't be getting to hot, i have a convertible
