Thread: GM Performance Parts HT383E for 96-99 OBS Vortec Trucks
    May 2007
    Las Vegas, NV
    Selling the motor I always wanted for my truck. I bought an HT383E for my truck, installed it, drove the truck for a couple of months and decided I wanted to go a completely different direction with the truck. :bang: Planned on keeping it for my Nova, but need some money to finish another project...
    Motor has less than 3,000 miles on it and is barely broken in. Ran great, pulled as hard as when I had my supercharger on the L31 with 7 psi.
    $3199 FIRM
    Check my feedback on ls1tech.com (username 350ss) and Ebay (username maxcornelius)
    17800393, GM Performance Parts ENGINE
    435 lb,-ft at 4000 rpm with 340 horsepower at 4500 rpm
    Part Number: 17800393
    Engine type: Chevy small-block V-8
    Displacement (cu in): 383
    Bore x stroke (in): 4.00 x 3.80
    Block (P/N 88962516): Cast iron with 4-bolt main caps
    Crankshaft (P/N 12489436): Forged steel
    Connecting rods (P/N 12497624): Heavy-duty PM steel
    Pistons (P/N 12499103): Hypereutectic aluminum
    Camshaft type (P/N 14097395): Hydraulic roller
    Camshaft lift (in): .431 intake / .451 exhaust
    Camshaft duration (@.050 in): 196° intake / 206° exhaust
    Cylinder heads (P/N 12558060): Vortec iron; 64cc chambers
    Valve size (in): 1.94 intake / 1.50 exhaust
    Compression ratio: 9.1:1
    Rocker arms (P/N 10089648): Stamped steel
    Rocker arm ratio: 1.5:1
    Water pump (P/N 88894341): Cast iron
    Recommended fuel: 87 octane
    Maximum recommended rpm: 5000
    Balanced: External
    Comes with Vortec style distributor, plug wires, spark plugs, new water pump, exhaust manifold gaskets (all have the same mileage as the motor) and new intake manifold gaskets. Basically what you would get if you ordered this setup new. DOES NOT INCLUDE INTAKE ASSEMBLY OR CRANK and WATERPUMP PULLEY
    May 2007
    Las Vegas, NV
    bump for new pics...
    May 2007
    Las Vegas, NV
    ttt...
    May 2007
    Las Vegas, NV
    last bump
