Thread: Auto to Manual conversion
    Mar 2008
    I am curious about the idea of swapping in a a 4500? into my 03 silverado. Besides the obvious mechanical parts, what needs to be done to the computer? Has anyone done this before???
    I know it will be a job, but I don't think its a problem, my last project was a 5.7 S-10 ZR2. I want my truck to be different......
    Maybe even a 6 speed? I see that some of the 3/4 ton truck have a 6 speed. (ZF S6-650) What about my transfer case?
    Tell us more about your truck's current driveline steup--and then we can tell you more...
    Mar 2008
    Sorry it took so long to reply.
    03 ext cab 5.3 auto buckets with the full console..... what else do you need to know???
    Why go with the NV4500? If you are going to do a manual swap, go ahead and get a T-56 from an F-body. But try and see if you can pick up a unit from a 98-02 model. Depending on your mods, you may want to upgrade some of the internals--like a LS7 clutch and flywheel ARP stud kit. You will need a new tranny crossmember, clutch pedal, and master cylinder. From what I know, the shifter location is pretty far back on a T-56--and you can buy a shifter relocation bracket that moves it like 5-6 inches forward so you can have the shifter up where your cupholders are. As far as the computer, get a custom tune. Everything is done inside the PCM through tuning software.
