Results 1 to 10 of 26
Thread: Fan don't go off
    Feb 2008
    Alabama
    Fan don't go off
    My fan stays on all the time now its probably the clutch right. Well im not going to try to fix it unless its something stupid or free. So what kind off options do I have for efans witch ones will fit with little or no fabrication? I have a friend at a junk yard out here that will give me a real good deal on whatever. So I would like to go with used if I can. I read about newer trucks having them stock. Can I use one out of a Camaro or firebird?
    Thanks!
    Apr 2007
    The land of wings and snow
    Search for ls1 efans or 05 efans, the 05 and newer trucks have them stock. I went with the truck ones because they just fit perfect, absolutely no fabrication. You'll find enough info on this site alone to be a pro installer.
    You do need to have the HD 34" radiator though for the 05 fans, the benefits of the ls1 fans is that you can fab them easily enough to fit your current rad if its the small one.
    -Matt
    He who dies with the most toys wins.
    (Still On)Summer-00 4.8 Silvy (Slow...Needs Bottle)
    (Still Off)Winter-94 FS Blazer (Almost ready)
    Pulls out friends- 93 1500 4.3 W/T Special
    Feb 2008
    Alabama
    I think I got the the small one ill check it out.
    Feb 2008
    Alabama
    I got the 34" I guess i'll be going to the junk yard this week hope I find some
    How hard are they to wire do I need a harness?
    ff_jeff Guest
    Quote Originally Posted by Riceeater View Post
    Make sure you are measuring the core and not the whole radiator. It should be 34 inches for the core and like close to 40 inches for the whole thing. Mine is a 28 inch core, and 34 inches all the way across. I have the smaller one.
    Quote Originally Posted by vff_jeff View Post
    ff_jeff Guest
    If you wanna look at that statement like a perv... then that sentance would be true, if I was comparing myself to a submarine.
    Feb 2008
    Alabama
    Do i use my fan housing I did a search so I know I have to have a bigger alt. ARe they stock in the 05s and up?
    Nov 2006
    Mesquite, TX
    e fans are stock in the 05 an up and no you dont need a bigger alt.....and you do not use the clutch fan housing
    San Marcos Texas
    You will need a wiring harness and computer reprogramming to make the fans functional.
