Results 1 to 9 of 9
Thread: HP Tuner Problem
    Feb 2005
    HP Tuner Problem
    I try to connect the hp tuner to my escalade but I get a message that its not connected to the truck, everything on the computer and hp stuff is connected right cause if I go connected to the yellow truck it works, what could this be? Do I have a burn fuse?
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
    Jun 2007
    i hate too ask but is it registered to the vehicle?
    Jun 2007
    o ive also had it happen when i turned the key on too early or later than i was supposed too.
    Feb 2005
    its not yet registered, but I just wanted to see the vcm scanner, it worked on my friends truck too. I'm going to keep trying. Thanks.
    2001 GMC Silverado
    Mine would not connect once and it was a fuse. I do not know which one though.
    San Marcos Texas
    It is usually the fuse that goes to the cigar lighter.
    Jun 2007
    no **** .i wonde if mine will be an issue next time i plug in my tune, my cigar lighter isnt working.well its my auxilary cigar lighter .interesting tho.
    Plug hpt into the obd connector only, does the box have power? If not, it's a fuse.
    Jun 2007
    hey allen i dont think anyone was gooing to put it in theyre lighter.lololol h/s thats frikkin funny.
