Results 1 to 2 of 2
Thread: votech5.7-vortech7.4
    Feb 2008
    Thumbs up votech5.7-vortech7.4
    hey all this is my project 99 2 dr. tahoe 4x4 converting to 7.4 4L80E 243 push button t case ho has push button already want a very clean swap donor truck was a 98 2500 2x4. Bought used trans.tcase for the swap only part that concerns me is i have a 2 whl. harness,(no case wiring) plan on carefully removing those plugs,wires right to the pins on the fire wall plug and inserting them on the 2 whl. harness. Every thing else is swap and plug using the extra coolers fans and condenser also after the exhaust and drivelines are built and running my thoughts will turn to drive train. as if all have a choice right now is running 35"s six inch fab tech lift. im thinking married 205 and i have a dana 60 front out of 99 dodge 3500 non dually and the corp 14 big bearing 10.5 rear both in 4.10 ratio i will do a 4 link pan hard bar set up on coil overs on the front (coils on rear dont want to cut floor for shock towers) any way thanks 4 reading any input is welcome
    Feb 2009
    South Florida, Venice.
    No idea where to help you on that one except good luck and I look forward to seeing what you come up with.
