Results 1 to 10 of 19
Thread: FS/ CompCams 13755-kit Rockers Like Brand New
    Aug 2005
    Spring, Texas
    Hey Guys,
    I have a complete set of Comp Cams 1.75 Rockers. I had them on my truck for less than 500 miles and decided that I needed other things and went with a totally different set-up. These are literally like brand new and i paid $415 for these about 6 months ago. I am asking $250 plus shipping. These were installed and uninstalled by proffessionals at TRT Performance in Arlington, TX. This is a steal and this kit comes with the following:
    (16) 1.75 Pro Magnum Rocker Arms
    (8) 5/16 Guide plates for 5/16 Pushrods
    (16) 3/8 Rocker Studs
    (16) 3/8 Adjusting Nut
    (16) Set Screws
    Here are the pics of the Comp Cams 13755-KIT
    Thanks and you can PM or Call Me with Questions.
    I will take Paypal, Money Order or Cashiers Check and will be Shipping the kit by UPS from Whitney, TX.
    Brent
    Bulldog5.3
    817-907-1830
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Aug 2005
    Spring, Texas
    Bump
    Aug 2005
    Spring, Texas
    Anybody???
    Aug 2005
    Spring, Texas
    Someone needs some Rockers?????
    Jun 2007
    this is a good price i have had several sets and pd much more.
    Aug 2005
    Spring, Texas
    Thanks Ramsey!!!
    HotRodV6 Guest
    I was looking at a set of these, but in the 1.8 or the SLP 1.85 ratio, did you notice any more power from them over the stock rockers?
    Aug 2005
    Spring, Texas
    Yeah I did and the guys at Comp told me to expect 10-15 at the wheels
    HotRodV6 Guest
    where is whitney at? close to houston by chance?
    Aug 2005
    Spring, Texas
    Wow that is so wierd! I am moving from Whitney (by Waco) to Spring, TX this week and it is about 30 minutes North from Houston.
