Results 1 to 10 of 11
Thread: 4x4 front lowering???
    Hey everyone, Im sure its been asked several times over but what dose everyone think of dropping the front of a 2000 sierra? How far can I go just cranking the torsion bars? Is it safe? Should I use lowering keys? I am on a budget so keep that in mind, but I would like to go with a 2/4 drop. Thanks
    Jeremy
    2000 Sierra 4x4 Denali front, 5.3, 3/4 drop, 22 foose speedsters, roll pan, Cold Air, Cat-back.
    If you like the look of rake then do it. Were you gonna drop the back as well or no?
    Yuo can get an inch or so but you will need an alignment. I took the 2" riser blocks out of mine and torqed the fron down an inch or inch and a half.
    Later I did the 2 4 drop.
    Read this article.
    2004 Chevy Silverado - Modified Truck, Custom Truck - GM High-Tech
    Then this one.
    Collection of Lowering Notes and Best Practices - SilveradoSS.com
    OK, so what I'm thinking is going with lowering keys that I have seen in truckin mag for $50.00 [anyone ever use these] to take the front down 2 inch. As for the rear I want to go 3 inch by using lowering shackles and taking out my stock blocks. I am also running 22s do you think this might be a probloms rubbing? Thanks for the help guys!
    Jeremy
    look up the guy named MOOSE we dropped his Z pretty far and he rolls 22s he'll be able to tell you what you need.
    Wasilla, AK
    What size are your 22's? Do you know the width and offset of your wheels? This will decide if the 22's will rub.
    There a 22x10 with 305 45 22 tires. As for the offset Im not sure but there right at the body line. There the ones that are on in the pic.
    Jeremy
    Wasilla, AK
    Quote Originally Posted by Jeremy K View Post
    They will rub. 275/45R22 on a 22X9.5 with +15 or +18 offset will fit, lowered, without rubbing.
    Wasilla, AK
    Your setup is what we sell for stock-height trucks that want to fill out the wheel wells.
    and gives a quality ride, low profile tires look good but ride like a$$...
    2003 silverado z71 rcsb 5.3 4L60E k&n intake system, gibson super truck exhaust, pcmforless tune, custom alpine stereo, hellwig sway bars fromt and rear, 3in drop in the front 4 in out back, powerslots f & r hawk pads. truck was intended to autocross, tow and bring the trophies home......
