Thread: 6.0 heads on my 4.8
    Your Moms House
    6.0 heads on my 4.8
    What will the achive if anything im just curious and looking for more cheap hp
    nevermind i found out what i needed to know
    HotRodV6 Guest
    so is there any power to be had by putting on 6.0 heads???
    Your Moms House
    no not unless u mill the 6.0 heads or get a thinner gasket becuase when u swap them it drops ur compression
    Jan 2006
    I do not think they will work. I think the valve will hit the bore? I could be wrong.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    HotRodV6 Guest
    no i dont think the valves will hit, but it will def drop the CR, might not be a bad deal for a turbo build.
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    Quote Originally Posted by HotRodV6 View Post
    I'm working on a set of small valve 317s. I have to pick them up and get them to my head guy to port the runner, install a new valve seat, and flow them at a 1.89" intake I'm thinking around 260-280cfm @ .550
    Plus the 10cc gain in chamber volume I estimate to drop it to around 8.4:1
