Results 1 to 10 of 19
Thread: Truck not level after lowering rear....help
    Aug 2006
    McCurtain County, OK
    I have the McGaughy's lowering shackles on the rear of my truck(04 ECSB). Problem is, when you look closely at the truck, it appears that the frontend is now higher than the rear. Not much, but noticable to "truck" enthusiasts. Is there any way to lower the front only a small amount(probably less than an inch) without having to buy a complete kit? I would like to go 4/6 later, but just don't have the extra funds right now. Any info would be greatly appreciated.
    2004 ECSB Silverado LQ9 6.0L Superchips;14.0 @ 96: 4900lbs of Fun
    69 Chevelle Coupe LS1/A4 swap
    Apr 2005
    Is your truck torsion bar front? if so, just loosen the t-bar bolt and it will come down.
    Gone, but not forgotten!
    Aug 2006
    Quote Originally Posted by SCIV View Post
    I think so. It is an '04 ECSB. How exactly do I go about this, and I probably should have it aligned afterwards?
    ff_jeff Guest
    got pics of the new level? I wanna see how bad it is cause im getting the same thing
    Aug 2006
    Quote Originally Posted by vff_jeff View Post
    These were taken right after it was done, and it looks pretty good here. That was last year, and since, I think the suspension settled somewhat. I'll try to get a current pic later after work.
    Before
    After
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by 69chvelle View Post
    look about in the area towards the back of the trans you will see 2 bolts on each side of it that the head is pointing to the ground...just losen them up about 2-3 full turns and make sure you turn them both equally...i will get you pics in a sec when i got outside
    Aug 2006
    Quote Originally Posted by mean05 View Post
    This torsion bar thing is what I was wondering about. I thought I had heard this somewhere, but couldn't find it in the searches anywhere. Does the truck need to be off the ground when you do this, or is there not any tension on the bolts? And is the truck going to lower as I do this, or do I need to drive it and let it settle after the adjustment? And I'm assuming it needs to be re-aligned afterwards?
    Nov 2006
    Mesquite, TX
    i didn't need to re align mine i only took it down about an inch this is the bolt i am talking about that you need to turn, there is another one on the other side also
    Apr 2005
    did it come with the 6.0L? if so, it is probably a 2wd SS?
    Aug 2006
    Yes, it is the VHO with the factory 6.0L. I like to call it a 2wd SS
