Results 1 to 10 of 12
Thread: efan needed
    ff_jeff Guest
    efan needed
    Ok for you guys that have done the Ls1 efan upgrade, What all do I need to do this? I have a ls1 efan assembly and thats it. I need list of everything even how you mounted it please!!! Thanx guys
    Dec 2003
    Azle,TX
    Order the harness from Allen...its plug and play.Also use2bfo did a write up on factory parts intall...looks very nice btw. Look it up and you decide which way to go.
    Vortec Performance Tuned
    ff_jeff Guest
    Ok Ive read My ass off and all ive found is people having problems with the fans not turning on high when the should. Do I need to get my vcm retuned? or can I just plug it in? Also he sold his nelson harness shortly after buying it and used a gm one. Why did he do that? Anyone?
    Dec 2003
    Azle,TX
    Something about fan speed...the factory harness has 2 speeds for the fans and nelsons harness is only one....Amp draw is another factor.There is alot to read i know,just make a choice by what works for you.Are you more confused than when you started...lol
    ff_jeff Guest
    Iam more confused now. Im not knocking nelson but i dont want to have cooling problems. Im sure some one has an ls1 fan setup that can help me out, I hope. Would it be better to just have it stay on constantly? And i dont want to get an upgraded alternator yet either. Help!!!
    is that the one that sticks a prob in the radiator for the temp readings?
    Dec 2003
    Azle,TX
    One more thing to consider...use2bfo wanted his to work exactley like OEM fans.Its not just an on off deal....I built my own using hayden thermos and hayden fans...they work ok i guess
    Jul 2005
    Azle , Texas
    04 truck Efan problem using pins 33 and 42 - Page 3 - EFILive Forum
    $40.00 bucks for harness works just like factory one .
    Post #27-28
    Now what is a tune again?
    Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
    Quote Originally Posted by use2bfo View Post
    Post #27-28
    Linky no worky
    Jul 2005
    Azle , Texas
    Linky no worky
    Weird , I checked both in your post and the original post worked both place .
    I know it is EFILive and not HPTuners , ls1tech.com has the same conversation and relevant material .
    Must be I use Fire Ferret , and some obscure Lizard OS .
    04 truck Efan problem using pins 33 and 42 - EFILive Forum
    ff_jeff Guest
    all they say is to build my own. but what about harness? I think i might just make it stay on whenever the truck is on.
