Results 1 to 9 of 9
Thread: drop shackles problems
    I bought 2 inch drop shackles and i can get the hanger bolts out but the leaf spring bolt wont budge. I can get the nut off but the bolt is froze. I've tried a impact and a breaker bar and it wont turn or anything. What is your suggestion on getting it out without destroying it?
    ff_jeff Guest
    Maybe try taking weight off it.
    The leaf spring is still attached to the shackle with the bolt stuck in it. The shackle is disconnect from the hanger, so there is no weight or binding. I can take the shackle and wiggle it but the bolt wont move
    ff_jeff Guest
    oic, you could always try heat, or cold, It worked in shop class, imo
    Aug 2003
    Spring, TX
    can you get a pic?
    i am having a hard time picturing what you are talking about.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    spring TX
    knock the $hit out of it with a hammer. works every time.
    Try spraying a bolt penetrant or WD-40 in and around it. Let it sit for a while so it can work it's magic... Make sure to put a floor jack under the rear end so that all of the binding tension is of the bolt. Then smack the crap out of it with a small sledge hammer....
    get a bigger hammer??
    2003 silverado z71 rcsb 5.3 4L60E k&n intake system, gibson super truck exhaust, pcmforless tune, custom alpine stereo, hellwig sway bars fromt and rear, 3in drop in the front 4 in out back, powerslots f & r hawk pads. truck was intended to autocross, tow and bring the trophies home......
    i'll try thanks alot for the help
