Results 1 to 10 of 10
Thread: lq9 heads
    Oct 2007
    weatherford,TX
    lq9 heads
    i found a set of patriot lq9 stage 2 heads 72cc for cheap would these be a good move or bad move for daily drive , already have asm long tubes ported tb throttle body spacer high flow cats and true duals plan on installing hpe c cam package 232 duration and 594 lift and small stall
    Aug 2006
    Willis, TX
    depends, what r u putting them on...4.8, 5.3 6.0?
    thats pobably going to be way too much cam for you!!
    again depends on the application.
    becareful buying anything from HPE...I had a bad experiance dealing with chuck the owner.
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
    Oct 2007
    weatherford,TX
    its a 5.3 what was your bad experiance
    Oct 2007
    weatherford,TX
    but what do u thank on the heads
    Apr 2003
    League City, TX
    Quote Originally Posted by 06-crewhauler View Post
    what's a stage 2 head? What do they flow at, and at what lift? Are the heads milled?
    Unless you're putting a turbo on that truck, 6.0 heads on a 5.3 will make you loose compression. They have a bigger combustion chamber.
    Mine - 04 Crew Cab Silverado 2500, 6.0L - L92 heads/intake - 4L80e - 4wd
    Wife's - 08 Trail Blazer LT - stock - every option - slow !
    Vid of my old Silverado 6L <---
    99 Fountain - 27ft Fever - 502 mag MPI :-)
    spring TX
    I have the same cam in my truck. I like it but with no stall theres no power down low. chuck is no good, x2 on the bad experiance. if you get that cam mack sure they put the patriot springs and not the comp 918s, in my 5.3 they lasted 2 days and the motor was screwed. no help at all from chuck after spending 1,800$ with him 2 days before.
    Aug 2006
    Willis, TX
    he had my tune all screwed up... with out going into all of the details, the bottem line---the guy is a jerk! not just a jerk but a F@&#37;king jerk.
    As far as your heads 72cc you will loose compression on a 5.3 i don't think you can even mill them enough to keep your stock compression.
    Facebook
    Oct 2007
    weatherford,TX
    well i guess since i am not going to use them anybody want to buy them
    Oct 2007
    weatherford,TX
    900 bucks thats what i payed for them
