Results 1 to 10 of 14
Thread: Air/Fuel guage Install????
    Mar 2007
    Pittsburg, TX
    I just purchased an Auto Meter A/F guage, Does any one know what wire and where i need to tap into, to recive the signal.
    Thanks Guys.
    My Ride: 2006 Chevy Vortec Max, LQ9, 4X4, no cats, 50 Series Flowmaster in factory pipe, 20"s, C.A.I., Custom tune by Dustin at TRT Performance
    Jun 2007
    should be just a keyed pos and then plugins for the rest.did you get the w/b a/f.?
    Mar 2007
    Pittsburg, TX
    No I did not get the wide band. There are three wires that come out of the guage,(red-12vswitched, black-ground, Violet- sensor wire).
    The directions say to splice into the +voltage wire coming off the o2 sensor.
    But I dont know which wire that is.
    Mar 2007
    Pittsburg, TX
    Can anyone help me???
    ff_jeff Guest
    if it were me And I couldnt find the answer online id get a buddy, a test light, some high heat tape and try each wire. might have to have truck on, wich is the down side. but hey its 1:10 in the mourning and im tired, so dont listen to every thing i say
    Since it is the 3-wire one, tap into the black colored wire.
    Wait...is the O2 sensor the 3-wire or 4-wire?
    Last edited by txarkitekt; 10-26-2007 at 02:12 PM. Reason: misread the original post
    ff_jeff Guest
    i think its the 3 wire
    Hutto TX
    3 or 4 wire, the two like color wires are either (+) or (-) since the heater doesn't care as long as it gets a circuit. so if its like a white, a grey, and two blacks...tis not the blacks. If you stick a DVOM on the correct wire it should tick between 0.00V and 0.99V
    1991 Silverado ECLB
    LM7-T56
    Dec 2003
    Azle,TX
    My 04 was the white wire...
    Vortec Performance Tuned
    Mar 2007
    Pittsburg, TX
    Well I have goten it hooked up already, I used a pink wire w/a white stripe up by the computer. I looked at 2500HD6.0's set up and that was where his was hooked up by Allen. It works, but at wot it bounces from super rich to one light in the lean area, even at a steady cruise speed it is still constantly jumping from one extreme to another.
