Results 1 to 7 of 7
Thread: Tire diameter?
    Oct 2003
    Houston
    I have a 17inch wheel combo which measures a total diameter of 27 inches. I think that the stock was around 30-34 inches i think. Can the smaller diameter be hurting performance. I thought that it would be better out of the hole and slower on top end? Any suggestions on this?
    99 Pewter SCSB
    DJM 4/6 drop, Hotchkis front/reat swaybars,Hypertech power programer, milled & built heads, Accel wires, distributer,coil, Mass Air Flow Sensor(mti motor sports, Granatelli),Dynomax UltraFlow Stainless, 17x8.5 Eagle Alloys, Escalade door handles, Suburban front grille, with clear corners and billet bowtie,Street Scene mirrors, Cowl Hood
    Decreasing your tire hieght has the same result as installing lower gears. So, yes you will see quicker launches, but that lower tire/gear requires more power up top.
    You're right, what kind of problems or concerns are you seeing,
    allen
    San Marcos Texas
    Lighter tire combos can help performance by having a lower unsprung weight.
    Oct 2003
    Houston
    Yeah thanks for the info! I was riding in my buddy's truck who still has the stock wheels and tires and his truck had a better pull in the freeway speed. It seems that my passing gear was not as strong as his. So what kind of so called tire/gear ratio has it become. My truck has the factry 3:42 rearend. How much lower is it now?
    99 Pewter SCSB
    Not much, i'd say not over a 3.90 gear ratio, there's a gear calculator out there somewhere, i'll keep my eye out for it.
    later,
    allen
    Oct 2003
    My truck has the factry 3:42 rearend. How much lower is it now? [/b]
    Depends on what the stock tire height was...
    If the stock tires were 30" then you went from 3.42 to a 3.80 effective ratio
    If they were 32" then effective ratio is about 4.05 (bigger change in tire size)
    2003 Silverado SS, Black
    e-fans, custom ram air, LS1Edit tuning
    Oct 2003
    Houston
    So is it better to put on an aftermarket tire/wheel package thats the same as the stock diameter, for over all performance?
    99 Pewter SCSB
