Results 1 to 5 of 5
Thread: air/fuel gauge
    Nov 2004
    I got my air/fuel gauge in and the instructions say to connect one of the wires from the gauge to the signal wire on the oxygen sensor. My question is which wire is the signal wire and which oxygen sensor would be the best one to get a reading from and why?
    Aug 2005
    St. Anthony, Indiana
    Sounds like you didn't buy a wideband afr gauge. The wideband comes with it's own sensor.
    The narrowband gauge is just going to be a light show for you.
    Nov 2004
    <div class='quotetop'>QUOTE(foggy &#064; Jun 28 2007, 11&#58;57 PM) [snapback]98086[/snapback]</div>
    Sounds like you didn&#39;t buy a wideband afr gauge. The wideband comes with it&#39;s own sensor.
    Right its just a narrow band, but I didnt get the one with the lights, this one has a needle. Those little lights flashing would get on my nerves. Does anyone know which wire is the signal wire?
    Jan 2006
    You need a wide band that is a stand alone gauge. They are more reliable. Allen set mine just behind the turbo. It works great. I went with an AEM wide band gauge.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    You need a wide band. I have the AEM too.
    Glad to see you are following the advice though&#33;
    Gone, but not forgotten!
