Thread: Custom Throttle Body
    May 2004
    Pickerington, Ohio
    Edit: Found out it is a shaner ported stock throttle body. Was told this by the seller, but it looks to be modified!
    Bought this w/ a LS6 intake off another member. I already have a P/P TB so I won't be needing this one.
    Looks to be polished, bump stop mod, idle hole drilled bigger, idle set screw adjusted open a little, blade screws cut down, epoxy filled then removed.
    Not sure what it is worth or if it is even worth it! To be perfectly honest, it is not the best looking TB I have seen. I am sure some one could do wonders with this! Comes with every thing in the pictures.
    Started at $70 - Shipped! OBO
    2007c CCSB 2wd lowered 2/2 Stock!
    2002 RCSB 2wd H/C 5.3l T56
    LQ4, 243, 228R, Holley Hi Ram, 4L80e, 4.56 - in the works!
    Aug 2005
    Houston,Texas
    Will this work on a a truck, if so i ll take it $60 shipped
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
    Dec 2003
    Newark, Tx.
    That does not look like a Shaner tb. No offense, but I have sold almost 100 of his and he is a personal friend, and that doesnt look like his work. He does not drill the blade and the epoxy job he does is 2nd to none. One of the first things he checks when I bring him a tb is to make sure the blade hasnt been drilled.
    Mar 2006
    Mesquite
    I posted the same thing on PT net...he said it was a Shaner but someone dremeled out the epoxy. ??
    May 2004
    Pickerington, Ohio
    Sorry guys! My email does not work on this board!
    I think at one time it was a shaner, at least that is what the seller told me. I will let it go for that price, but I think you should know that you will probaly need a tune and you idle will be off. You also might ned to adjust the set screws for it to idle also. Just a heads up so you guys don't think I am trying to rip someone off!
    May 2004
    Pickerington, Ohio
    Bump for the weekend!
