Results 1 to 9 of 9
Thread: Installed the pacesetter longtubes
    Mar 2006
    My truck was originally a 4.8 and now it is an ls1, i had to shorten the steering shaft bolt because it was rubbing the header. And on the passenger side the header is rubbing the frame rail.....has anyone else had these issues, could it be weak motor mounts??
    Dec 2003
    Azle,TX
    I put mine on tuesday and fit perfect....something is out of place...maybe a motor mount
    Vortec Performance Tuned
    DBYRD Guest
    mine hits as well, from what ive heard that is very common. also my steering shaft is rubbing but i think its motor mounts issues on that one. im replacing the crumple zone(ridges) in the shaft with a straight 1 inch piece of stainless steel to fix the problem.
    Mar 2006
    <div class='quotetop'>QUOTE(Allstar55566 &#064; May 18 2007, 12&#58;16 PM) [snapback]93912[/snapback]</div>
    I fixed the steering shaft problem by shortening the bolt that goes through it, but the header hitting the frame isnt good....I wouldnt think the motor mounts would be bad or weak, aluminum engine should be lighter. If I cannot cure it then motor mounts will be put in. I pulled it over with a ratchet strap earlier and sprung it a little so now I have some clearance but not enough for when I get on it, it twist right into it.
    thanks for the reply and keep em coming maybe someone else has encountered this&#33;&#33;
    Jarrod
    Oct 2006
    same here, my mounts are new though. replaced them when i changed motors of course but mine still hits the frame rail on passenger side.
    2000scsb silverado, &#39;02 5.3L with Comp Cams custom ground LS1 cam 222/224 112lsa +2deg. 581/581 , &#39;01 LS1 heads decked 0.010" ported, Comp beehive valvesprings, pushrods, shims, pace setter longtubes, no cats, Nelson tuned. AuburnGear Pro series LSD, 4L60E built with 2k rpm stall, corvette servos and raybestos clutches..... Fun enough...... for now
    Jul 2006
    College Station, TX
    Well you could nitch the frame rail and then fill in the nitch with a curved piece of metal. But you would have to beef up that area of the rail a little bit.
    This sounds like it would work but i do not know about safety or strength. Just an idea.
    2004 EXC Silverado 6.2L
    Mods:
    Feb 2004
    Sour Lake Tx
    Why dont you just get your headers really hot and bend the headers at the collector with a large piece of exhaust pipe. I did that to a set of hookers i had and it worked pretty good. just be careful that if you pry on the runners that you dont kink them any.
    I have heard nothing but good about pacesetters too. Makes me kind of glad that i took a gamble and got a set of stainless LT headers by a lesser known company. I didnt have any fit issues other than needing different spark plug wires for #5 and #7 but i kind of expected that to be the case as with almost all headers i have dealt with.
    EATIN' FORDS AND TUNDRAS
    <div class='quotetop'>QUOTE(carfreak07 &#064; May 18 2007, 01&#58;50 AM) [snapback]93853[/snapback]</div>
    I would return them. I attemtped to put them on my truck 4x4 with 5.3 and they fit perfectly but the broken bolt kept me from keeping them on. "the bolt in my head"
    Mar 2006
    I actually got it, I sprung them just a little with a ratchet strap while the ory clamps were loose, then i tightened the clamps before i let the pressure off. It still was extremely close so i then went and purchased a polyurathane tranny mount with three holes in it and pryed the tranny over about 1/2in and mounted in the left hole of the mount, I now have about 1/2 clearance between the header and the frame&#33;&#33;
    works like a charm&#33;
    thanks to all who replied,
    Jarrod
