Thread: NEED HELP!!!....CODE P0200
    I overnighted my tune got it today just installed it and truck runs like crap! I called Allen and he and John where both busy with customers. I went to the local shop they did the crank relearn and its throwing a P0200 code, something about fuel injector rail? I drove it home and put the stock pcm back in until I hear from someone.
    oh also have the harness for electric fans, its not turning them on? I touched the blue wire for pin 42 to the ground and they both kick on. When I put the wire in pin spot 42 and plug it into the computer it does nothing?
    01 1500HD- STS Turbo, Meth kit, Nelson tuned, 10inch lift, 35's,
    02 Escalade (STOCK)
    SOLD..02 GMC Denali Yukon- Lowered, Helo Maxx 20's, e-fans, Nelson Harness, Nelson tune, K&N intake
    SOLD!! 1995 GMC 5.7 350 with all bolt-ons, 9 inch lit, 35 inch tires, bushwacker cut out flares, 4:56 gears, detriot locker.
    Well I just got off the pone will Nelson Performance and they are sending me another tune. You guys where right about there customer service!!! ITS A+++++.
    02 Escalade (STOCK)
    Jul 2006
    College Station, TX
    They are great about making sure it is right.
    2004 EXC Silverado 6.2L
    Mods:
